Not enough target numbers
I’ve set up a page of four photo galleries (items) following the tutorial in the F5Pro for the Maurice Cowley site.
They work fine but I have the problem that there are four items each with six images, that makes twenty four images and the number of targets in the Action window only goes up to 22!.
I thought I had it wrong and that I could use numbers 1 through 6 over again. I did this and found that mouse overs on one set of images changes the others that I’ve given numbers 1 through 6.
Can I add more numbers in the Target Action window?
http://www.barnett-knits.com/whittonshow.html
Thanks, Carolyn
There are 20 "numbers’ each of which can be used with a different Target group ie Indigo, Rose. Slate etc (10 in all) which gives you a total of 200.
On your page you have used the default “Indigo” for every one.
Change each of your groups to use a different one.
Leave the first at Indigo
Change 2nd to Rose
3rd to Slate
4th to Turquoise
You can use any of the groups you like as long as you use the same Group name for each rollover group of images.
Dave, you’re a sweetie. That’s so easy but I didn’t delve further into the ref manual (if it’s there).
That’s so easy!!! I’ve posted that page now with a link but will tidy it up as soon as I get a minute.
Thank you so much, Carolyn
