I just begun with using Freeway 5 pro. I didn’t use the program for a while.
I have a problem figuring out how I can make an object ‘stick’ to the right side of the frame (so that it can move along when the browser frame is resized).
Can anybody help?
Make sure that the object is a layer (set CSS Layout to “on”, or check the "Layer "option in the Inspector palette if the object was created without CSS positioning).
In the Inspector palette, under “Dimensions”, set a value for the distance between the object and the right-hand side of the frame using the third box down. The object will now always move relative to the right-hand side of the browser window.
