Since ScreenCaliper never upgraded to run on Lion or Mt. Lion, can anyone suggest a good pixel measurement tool?
I use two -
Art Director’s Toolkit, which is several tools -
http://www.code-line.com/software/artdirectorstoolkit/
Pixus, which I got from Adobe… dunno who’s app it is but it rocks for just
rulers -
http://applevie.ws/2009/09/pixus-is-the-perfect-free-app-for-screen-object-measurements/
I use Xscope http://iconfactory.com/software/xscope which has a very useful suite of tools but it’s pricey.
http://xiiro.com
I’ve always used Command-Shift-4, which is the tool for taking screen-grabs of selected areas. Press the key combo, click and drag a rectangle around the thing you want to measure, take the measurements (displayed on the cursor) and press escape to cancel the screen-grab. Only downside is it can be a little hard to read on dark backgrounds.
Thanks to all!
