Is there a way to make pages in Freeway scroll smoothly when launched? See broxroofing.com or lcscrusaders.com. Both of these sites seem to build in chunks instead of a smooth scrolling from top to bottom.What can I do to correct this?
Do you have a site that you have built that we could compare to these? These sites are pretty normal, construction-wise. Nothing fancy or tricky being done within them.
The text is all graphic instead of HTML. Not only does this slow things down, it is also useless for search engines. Furthermore, users can’t re-size it. Graphic text is good for decorative titles or logos, but for the main text you should use HTML.
You’re using table-based design instead of CSS layers. Notably the navigation elements in http://broxroofing.com create a complex table and cut the background image into many parts. This would load faster if the menu items were in a separate layer so that the image behind them stayed in one piece.
