Julius
(Julius)
January 9, 2009, 2:57pm
1
Hi,
can’t remember if this topic has come up before but I find I can’t copy a text string and paste it into the save panel. See:
http://juliuspaintings.co.uk/intaglio/saveAs.png
I have encountered this phenomenon in a couple of other applications whose identity I forget, so I think it might be a Cocoa problem, vis error number -25130 is a Pasteboard manager error.
http://tinyurl.com/73zccs
Am I unique in getting this error? (Mac Pro, Leopard)
Has anyone found a workaround?
Best wishes
Julius
On Jan 9, 2009, at 9:57 AM, julius wrote:
Hi,
I don’t know but it works here on a Dual 1 GHz PowerPC G4 under 10.4.11
Regards
–schremmer
Intaglio mailing list
Same problem here on MBP, 10.5.6
Only I don’t get the error message, it pastes the text into the document.
Sorry no work around, however I note that drag and drop text is inserted into Save As panel.
