Hi ,
Just finished part of this site for someone I know and thought I’d put it up here… http://www.lynardrie.co.uk/nortonskiracers/home-ski.html
It was made in Freeway Express 4 and is not yet finished but the base of the design is there!
Thanks in advanced for any comments,
Fergus T
Hi ,
Fergus T
I think the top graphic area takes up a bit too much of the room
before you get to the real ‘meat’ of the site; if it were me, I’d
make it half as high. Coming on nicely though
Oh, and a couple of typos: ‘Sponsers’ should be spelt ‘Sponsors’, and
‘with the sun shinning on a crisp blue sky day’ should say ‘with the
sun shining on a crisp blue sky day’.
Hi ,
Fergus T
Thanks for the comments! Woops hadn’t noticed the typos. Had just copied what I was given into Freeway. Thanks for pointing that out. I can see what you mean about the header. In the area above the navigation I had placed two pictures but then deleted them as it looked a bit cluttered. I will give it a shot with reducing the size though, Many thanks.
Fergus T
