PHP Form - How to produce error msg when *required field is not filled in
I have a built a site with a simple feedback form.
Test site is here:
http://www.cmlcampaigns.co.uk/hub/enquiryform.php
The client insists certain fields me be filled in - *required
I also agree, I have set the form to produce a page for each individual error - works fine!!!
However if you fill in the form and miss out a *required field, e.g. Name - then form still submits??
How can I stop this happening, or at least stop the form from being sent if the mandatory field are not filled in.
Is there a way to produce an error message to say that the required fields have not been completed correctly???
Thanks guys
What are you using for your form handler? You say PHP form, but are
you using an Action or a hand-rolled script on the server to manage
the form submission?
If you download and use the PHP easiForm actions then they will handle
all of this for you, there is a small cost for easiForm but it will
save you a lot of time.
Tutorial: Tutorial: easiForm With Freeway
Example contact form that uses the PHP easiBase actions:
http://www.easibase.com/easicontact.php
Just press submit without filling in any fields and you can see the
errors returned.
If your server supports ioncube then the easiForm suite will save you
a lot of time.
HTH
Mike
Test site is here:
Thanks guys
There’s also the PHP Form Action at http://www.actionsforge.com/actions/view/2-php-form-action
and Validate form Suite at: http://www.actionsforge.com/projects/view/73-validate-form-suite
I have used both these and easiForm successfully, with a current bias
to easiForm which gives a simple one-stop option.
Choice depends on what you need to achieve.
Colin
handle all of this for you, t
I’m using the Page action - PHP Feedback Form and have applied a set page for each error.
Is this not possible using this action/method Walt?
As Mike has also posted, I am open to suggestions or an alternative.
Chris
I haven’t used that Action myself. My understanding of it from a distance is that you set a single error page to catch all errors, and the handler will not send mail if a required element is not filled in. The form will certainly submit, but there won’t be any output.
Form page → submit → decision:
Valid: send mail, redirect to success page.
Invalid: error page, directions to correct
That’s the tree as far as I understand it. Tim Plumb should be awake in another hour or so, maybe he can pipe up about this then. (He’s in the Seattle area/time zone.)
Sorry, I missed our original mail. The action only really cares about two fields
if they exist; name and email. If these field names exit and they don’t contain
a value then the PHP code will throw the user to the error page.
If you need to any further validation I would suggest you add the Validate Form
Suite (http://www.actionsforge.com/projects/view/73-validate-form-suite) and do
your value checking before the form gets submitted.
Quoting Mr worm email@hidden:
Test site is here:
  • works fine!!!
Thanks guys
Extend Freeway the way you want with FreewayActions.com
http://www.freewayactions.com
