Good day,
How is a graphic item positioned in a text flow?
My text is itself in another box (or several boxes), but when I publish the page or view it in a browser the graphic item “jumps” to the end of the text. Why is that so?
I have tested different ALIGN-options in the inspector,
such as Align: Bottom or Baseline, with the same result!
However on another part of the page it works just fine,
i.e. the graphic item just sticks to where it is supposed to be…
Good day,
Put the graphic in the same box with the text. Give the graphic a margin to wrap the text around.
Aha. The rest of your text is GIF text, but styled as HTML
paragraphs. You need to have all of the text in the box render as
HTML, or this inline GIF trick won’t work. Highlight all the text,
and in the Inspector, change the output mode from GIF to HTML. You
will need to adjust your styles to compensate, but you should be able
to do something very similar to this page with “plain” HTML text.
On Oct 19, 2008, at 8:39 AM, OmarKN wrote:
Yes - the insertion point is after the [ - bracket,
at: ( "publishing packages and [ ")
The graphic is: Resources/trgdown.gif
the style used: (style="vertical-align:baseline; margin:1px)
and tested with other align options w/out success,
