I’ve just introduced a new control in the “Start a new thread” form on FreewayTalk.net. If your question or tip is specific to Pro or Express, you may now indicate this with a tick of the appropriate box. Mail users, as ever, you may indicate the same thing with a [Pro] flag on the subject line (and that’s all this feature does, anyway).
In coming days I will add a similar control to the search boxes on each forum.
In the meantime, you can get the benefit of this by using the Boolean search operators + and -.
HTML borders
might net you thousands and thousands of hits to plow through.
"HTML borders"
(making a phrase by surrounding it in quotes) would reduce this somewhat, but probably still give you quite a few things to look through.
"HTML borders" +express
would cut the results down substantially.
"HTML borders" +express -pro
would probably return the most focused set of results.
Give this a try, and let me know if you think of any other features to improve the FreewayTalk experience! (I can’t guarantee that I can or will add them all, but if you grumble to yourself, then nobody gets anything better.)
