preview in browser problem
I am trying to preview in browser a site build in progress, it was OK earlier but now I get a screen message pop up saying the file i’m trying to import is probably invalid? Can anyone help?
What browser are you previewing in and what are the browser priority orders set in Freeway? IE, Firefox is primary? or Safari? Have you moved an html.index file? or re-named anything in relation to your present project?
Chris
Have you changed the file name to something obscure ie NOT mypage.html but mypage.blah
The pop up message is coming in Freeway so not a browser issue as far as I know and no file names been changed either, big mystery to me so far?
Steve
Chris
As far as I’m aware, I’ve changed no file names and no object names either?
Regards
Steve
Oh!
Personally, I would go physically to the folders on the system and check that everything is where it should be. Then I would try and re-trace my steps back to the time that it previewed correctly and remember if anything I did involved something well sort of extra, import, export. The i would shut everything down to clear out any RAM and re-start my computer. The latter has worked for me on some non-related issues that seemed absurd at the time.
Sorry I can not be of any solid help, just trying to put myself in your situation and seeing what I would do.
Chris.
Can you preview within FW?
Hi Guys,
Tried your re boot and it worked, I must have been working my poor little mac too hard, just needed a rest.
Thanks for all your help!
Regards
Steve
On 15 Dec 2010, at 20:08, Chris Watts wrote:
Oh!
Chris.
