It seems that occasionally when I make a change when I am in ‘Page,’ that change will not reflect in ‘Preview.’ I have tried refreshing the cache in the browser to no avail. Any suggestions?
Hi Ron if this happens do a complete publish…
So thats cmd ctrl P or hold down the ctrl key and then go File/Publish you should see that the Publish Site has changed to publish Everything.
What this does is republish all items on every page regardless if Freeway thinks that page has been untouched.
This is sometimes necessary, for example if you have used an extended attributes in styles, this occasionally fools freeway into thinking the page is unaltered.
