Print completed webform
I’m working on a form that my client would like people who are registering for a conference using the form to be able to print out a completed version of.
Anyone have a script or know of a way I can do this in Freeway? As a fall back I plan to use Forms to Go to generate a return email to the person registering but am interested to see if it might be a fairly easy task to generate a printed version of the form after its completed some other way.
Bill
Personally I use the Print Button action with a clear message:
Click here to print a copy of this form for your records before you send it! (In Bold & Red)
That seems to do the trick for me!
Thanks David, didn’t know about the print button action…is it on the FW website?
Bill
Yes its at
http://www.softpress.com/kb/article.php?id=186
You can also use it on a text link
http://www.softpress.com/kb/article.php?id=496
I should also add that it does work in the latest Mac browsers contrary to what it says at SP towers
FF 2.0.0.10
Safari 3.04
Opera 9.01
Thanks David, I’ll give it a go!
Bill
FF 2.0.0.10
Safari 3.04
Opera 9.01
