[Pro] 2 options desired for CAROUSEL action
Hi,
2 actions that I think would be amazing for the CAROUSEL Action would be
  1. when you click on the carousel pane, you could click to activate or not instead of taking off the action to skip over a pane
  2. Adjust how long a specific pane stays on (for more important displays!)
ex panes 1&3 might be 5 seconds but pane 2 might be 10 seconds
