Question 1. How do I get divider into the page, so it does not look so crowded?
Question 2. How do I embed a google calender or any calender into freeway,so that a client would be able to update the calender and it would update on her website
http://www.hgrantdesigns.com/betterbibs1/products.html
Richard
(Richard)
July 25, 2014, 2:09pm
2
Put your cursor somewhere in your HTML item and go here : Menubar > Insert > Rule . That should do it.
I’ll skip that one, never done that.
If you Google “embed a google calendar” you’ll get the answer.
Use an iFrame to display your Google Calendar using the source which should be something like
The code for this is on your Google Calendar page
