How does one go about getting three columns or more uneven number of columns, in a Freeway Pro box model design? I can see how to do two columns, and even 4, by putting another two HTML boxes inside of two existing HTML boxes. By with the float choice of only left or right, a third center column eludes me in trying to do a simple three column layout in box model. I have a feeling it’s an easy answer. – Lewis
They don’t have to be either left or right you could have one left and 2 right.
Try it.
Correct and could end up in the so called divits, but indeed a do-able way and I did this method for many years.
In my screencasts, I usually go another way which is called:
Approve eventually that you can’t do it key-visual in Freeway and choose a width of 33% (or 16% or whatever) and adjust it with the extended dialog to the real browser width of 33.333333% (given that box-sizing: border box is set if you use padding).
