Just went to check out a site I did the end of 2008 using 5.1, I now have 5.3.2 and find the positioning of the inline divs has gone all askew to the point that I can’t figure a resolution without taking the pages apart and starting again. The div containing the css menu and aligned left for example has decided to reposition itself further to the right and encroaches upon the adjacent main text div.
Thankfully i still have 5.1 so saved to a point. Has anyone else found this problem?
The intermediary upgrade 5.3.1 is even worse.
There shouldn’t be any issues. Could you give us a bit more
information, or even better, send the offending file through to
support(a)softpress.com so we can take a closer look please.
On 10 Apr 2009, at 22:40, seoras wrote:
Hi,
found this problem?
Thanks for reply. I’m trying to untangle things at the moment, I’ll send through the file.
Probably the way I set things up originally, though it works fine.
