[Pro] 5.4.3 upload issues
I’m unable to upload from Freeway 5.4.3 to Bravehost yet when I use the exact same server, username, password in Fetch, I connect right away. I have tried with “Passive” checked on and off. Freeway just won’t connect and I get a “Cannot connect because the FPT server is not responding.” (But it responds just fine in Fetch.)
I am using ftp, not sftp, (5.4.3 does not support sftp.) The host is configured to take ftp and Fetch is configured the same way. Since I can get in with Fetch, no problems, I can only assume that it’s something in Freeway.
Any suggestions?
Make sure that Freeway is set to save its FTP logs (general
preferences) and then try again. Your FTP log will be somewhere in
[your account folder]/Application Support/Freeway 5. Mail them to
support(a)softpress.com along with a note describing your troubles,
and I’m sure they’ll be able to help you out.
Any suggestions?
