Put all of the following inside one all encompassing box: item1a with all the accordions, footerline, and miuproducedbytagmastercopy. With them all in one container they can grow and shrink together.
I’ve done all of that and even Walter gave me the tips that got me in the right direction. Thing is, whenever I hit the height inspector box for the all encompassing stretchy box, it keeps reverting to zero. I’ve tried removing all the effect except for accordion and every time I click that box it goes to zero. I don’t think its suppose to do that… I’m stuck.
The reason it reverts to zero is that you haven’t added the child elements as inline children. Try this: set the outer box back to fixed height, then drag it a little taller for good measure. Click on the top child element (your FAQ), and cut it to the clipboard. Now double-click in the outer stretchy box until you see a flashing text cursor. Paste. Now do the same for your footer. Finally, click once on the outer stretchy box and disable its height attribute.
Walter you ROCK! I wasn’t cutting and pasting. I was dragging or cutting and pasting incorrectly. Thank you so much!!!
