[Pro] Accordion and jQuery
Hi,
Which accordion can I use that won’t clash with JQuery on the same page?
Sly.
A JQuery based one!
What are you doing in JQuery that cant be done with one of the FW script/protaculous actions?
Here is a quick example http://www.deltadesign.co/examples/jqueryacc.html using JQuery.
Based on code from http://css-tricks.com/case-study-jquery-fixer-upper/
Or this ScreenCast I have:
http://danjasker.com/store/fw8vc
Thanks chaps,
The JQuery I’m using is for a ‘Reset’ button that only clears certain parts of a form.
I’ll have a look at your suggestions above and work out a fix.
Thanks again, both of you.
Sly.
If you post your JQuery code I am sure that someone could convert it/provide the Script/Protaculous equivalent.
Good idea Dave. I’m sure I can work up a JQuery Accordion with the help you’ve given me above. But out of interest. The clever bit of JQuery that resets only part of a form can be seen in action here, along with the code: http://www.electrictoolbox.com/jquery-clear-form/
See what you think.
Sly.
So why not just use the vanilla javascript method that he outlines http://www.electrictoolbox.com/javascript-clear-form/
I suppose it’s obvious. I just thought JQuery is a derivative of Javascript and therefore javascript would clash with Scripty/Moo also.
Thanks Dave, I’ll try it.
