[Pro] Accordion or Carousel
I want to create a accordion/carousel like effect for a navigation. Saw a couple of nice ones. Any suggestions on how to create these effects?
http://www.bentleymotors.com/ (the bottom banner)
I would be very grateful for any help from you seasoned experts. Thanks
Sverker
Not sure I can offer much help, other than to say that Walter’s Carousel Action is very easy to use and I think it would work for what the Bentley site is doing.
Not sure how I would tackel the catamaran site…would love to hear what the pros think about that. I just saw that the EWA flash software that Softpress is promoting could create something like that.
Hi Sverker
Have a look at BannerZest Pro http://www.aquafadas.com/en/bannerzest/ It would do the catamaran effect for you.
Regards
Lee
Sverker,
The Catamaran site effect is achievable using javascript and mootools, although I am unsure how to implement it in Freeway. See this page for details:
Try the ScriptyAccordion Action, in horizontal mode. It shouldn’t be
that tricky to do. Use inline images as your headers, interspersed
with inline DIVs (HTML boxes) for the content. The only trick is to
set all the contents to float left and to avoid inserting any extra
paragraph returns inside your main outer container element.
On Apr 18, 2010, at 12:00 PM, ralfy wrote:
Sverker,
http://phatfusion.net/imagemenu/
Thank you all.
I understand that there are several ways of doing things in Freeway… I shall try them all.
THANKS!!
Sverker
