[Pro] Action titles not showing in box
Building my 1st with FWP so not published yet. What am I missing, something simple I’m sure. On the work page when I insert an action a box appears but has no title, making it invisible on my work page when I click off of it. It’s a little difficult to design with invisible boxes. Inserted the Link to PDF action and actually have it working but CANNOT SEE IT on my working page, does show up and work in preview mode. Tried a few other action on the page and the same thing is happening, box with 4 handles shows up but no action title within the box. What am I missing? Thanks in advance for your help.
Check VIEW and check the lines you want titles to view in boxes in
workmodus.
2014-07-14 18:38 GMT+02:00 dnafreq email@hidden:
Am not sure what is meant here, but one thing should be the very first step (even before inserting the first item):
“Show items”
by click on the lil cog bottom left:
This is showing all items placed on a page (the green rectangles listed below each page). From there you can select them and rearrange (if necessary).
In general, it’s always a good idea to overwrite the default names "item123, item124 … " by something more meaningful - such as “header-box”, “footer-box” or “main-content-text” - not really semantic, but something which indicates a function of the placed items.
Happy placing.
Also look in the View menu, and make sure that Outlines and Titles (optional) are enabled. The former puts the box around things, and without that you won’t see anything.
“Show items”
Happy placing.
Thanks for the help, got it. Knew it was something simple I was overlooking. And thanks for the tip on renaming the default item names, that will be very helpful soon. :slight_smile:
