Hi there,
I’m using scriptyfader for a website which works really nice
I’m using it to show/hide boxes with texts. Within one of those boxes I wanted to add a carousel but for some reason that won’t work. Also other actions (i’ve tried several) don’t work within a scriptyfader option.
No. The content within the ScriptyFader Option is ripped out of the
page and saved separately in a new file. This can break the JavaScript
connection between any code in the head of the page and the fading
options, because the page loads only once, while these elements are
loaded asynchronously as the fader effect runs. They’re not there at
the one and only “onload” event, so they aren’t set up with their
Action-driven effect.
On Jul 8, 2011, at 6:20 AM, wfa.vanleeuwen wrote:
Hi there,
