Hi Trevor - were guess here as I’ve never used EazyMovie before, but if it’s anything like Hype or WOWSlider, then you would:
Publish the movie.
Copy the movie and associated folders to your webspace
If EazyMovie has generated an index.html file, then open this up in a text editor and you’ll see the relevant bits to paste into your Body section, as you state below
From this same index.html file there may a part of the code that says something along the lines of “<!— Start EazyMovie.com BODY section” and “<!— End EazyMovie.com BODY section”, in which case copy the in-between code (including these 2 quotes above) into possibly a Ccrowbar action inserted in the correct position on your Freeway page.
As I say, purely guesswork based on my use of Hype and WOW, but it may push you in the right direction.
Good luck
Another Trev
On 29 Oct 2015, at 10:45, t50ufo email@hidden wrote:
Need instruction to place movie on FW Page.
I upload movie file folder to server.
I have auto generated code to be pasted between tags
.easyhtml5video .eh5v_script{display:none}
Is the part that goes in your Crowbar action - and for the bit that goes between tags , I’m afraid I don’t know.
That’s about as far as my knowledge goes I’m afraid.
best
Other Trev
_______________________________________________
I would think that this is to do with the positioning of your Crowbar action.
Not knowing how your page is constructed, I would suggest you do everything inline, place the Crowbar Action in an inserted HTML box, align the box “auto” (so it floats centrally) and then size the box to max width and height of what your movie is - or flexible, not sure what would work best.
best
TrevReav (the Other Trev)
On 29 Oct 2015, at 11:56, t50ufo email@hidden wrote:
Thanks other Trev
Thanks for that TrevReav
Made some progress!
Placed all the code minus the script line into crowbar action
Placed the script line in page markup Before
Video shows ok but is to left of page.
Can any kind soul tell me how to centre it in the page?
Totally out on a limb here, as I’m not brilliant at understanding code so I’m probably going to make a complete numpty of myself.
Looking at your code for the page, I see that a couple of resources aren’t loading - Sparkle/engine1/jquery.js and Sparkle/engine1/style.css. Is it possible that the style.css file could have the instructions to centre the movie?
Also, I can’t see any wrappers that are set to auto align.
best
OtherTrev
On 29 Oct 2015, at 13:20, t50ufo email@hidden wrote:
Thanks again TrevReav
Yea, think that is what I have done - checked all and still can’t get it to centre.
Live page here if anyone can see what I have done wrong.
Placed the Crowbar into a template page. It is still not just right.
Centres OK when I shrink browser width but at full size it is still off to the left.
Afraid not - I think that’s the extent of my knowledge, although I do still think it’s something to do with the page construction rather than the movie itself.
Best of luck
OtherTrev.
On 29 Oct 2015, at 16:02, t50ufo email@hidden wrote:
OK
For reference this is the sequence - hope it helps someone else:
Walkthrough to add EasyHTML5Video to Freeway Page
Open the html page that has been created by EasyHTML5Video with text editor.
At top of document - cut the snippet from that includes this: margin: 0 auto;
and Paste it into FW Page markup Before
At the bottom of the html page cut from line and paste this into the same markup Before
Place Crowbar action on FW Page where required
Copy all code from and including Start Easy… to End Easy… and paste into Crowbar Code Action window
ensure that the line you used above has been removed from this snippet of code
Ensure the folder eh5v.files is in the same place as your page with the video on it
