purity
(purity)
March 28, 2016, 1:45pm
1
Hello all,
once again a question about a sticky footer …
What do I have to do to integrate the following js into my freeway page.
I added the two script links bevor /body (the footer js with the correct path) and called the footer “footer”. I fiddled around a bit, but can’t get it to work. Do I have to add some extra attributes or is something else missing …
A “little help” would be appreciated. Maybe somebody can guide me to the right direction …
That’s the script: GitHub - engageinteractive/sticky-footer: Very simple sticky footer jQuery plugin
Thanks in advance
Ray
http://www.grayfix.at/SF_test/
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
You have given your footer the Class of .footer - it should be just footer ie
Item > Extended Name = Class, Value = footer
Likes: 1 ❤
Though after closer examination I am not sure that this script will work with your page construction - why did you pick this script in particular?
Likes: 1 ❤
purity
(purity)
March 28, 2016, 4:26pm
4
Hi Dave,
thanks for your answer. I corrected the values like you’ve said, but it also do not seem to work.
First I try to find a free-way to get the footer sticky (with the help of this forum), but didn’t get it done (www.plancfilm.com ). Now if the site is online, I’m trying to optimize this extemporary solution and this script looked “easy” on the first sight …
greetz
ray
Likes: 1 ❤
Yes but I think it requires a certain basic page construction method.
I will have a closer look at your page later and see if we can offer an alternative or fix.
purity
(purity)
March 28, 2016, 4:53pm
6
Hi Dave,
that would be great! Thank you in advance
greetz
ray
Likes: 1 ❤
This uses a pure CSS solution
http://www.deltadesign.co/plan-c/plan-c.html
However I am not sure how easy this will be to retrofit to your FW page.
Can you copy this page from your FW doc (select it in the site sidebar, copy) and paste it into a new Blank FW doc.
Then Save > Archive and zip the archive and email/dropbox it to me.
You will get my email at my People page
Likes: 1 ❤
purity
(purity)
March 29, 2016, 4:34am
8
Hello Dave,
looks perfect, thanks a lot!
Here’s the link to the freeway doc: Dropbox - Error - Simplify your life
I’m just not sure what you mean with your “people page”. Can you plz send me the link?
Thanks in advance
Ray
Likes: 1 ❤
If you are viewing FWT online there is a Tab down the left that links to People - my entry has my contact details.
That was fine as far as it goes but because you Did Not Save > Archive none of your graphic files were included.
I’ll see what I can do with it.
purity
(purity)
March 29, 2016, 6:05am
11
Oh sorry, replaced the file with the archive: Dropbox - Error - Simplify your life
Likes: 1 ❤
OK - try this - another JS solution.
Add this via Page > HTML Markup replacing anything you have already in the Before end Body section
<script src="http://code.jquery.com/jquery-2.1.4.min.js"></script>
<script>
$(window).bind("load", function () {
var footer = $("#footer");
var pos = footer.position();
var height = $(window).height();
height = height - pos.top;
height = height - footer.height();
if (height > 0) {
footer.css({
'margin-top': height + 'px'
</script>
Likes: 1 ❤
purity
(purity)
March 29, 2016, 7:06am
13
Hi Dave,
have to go to work. Will try it in the evening.
Thanks a lot for now
Gretes
Ray
Likes: 1 ❤
purity
(purity)
March 29, 2016, 5:50pm
14
Hello Dave,
I replaced the script as you said and first the footer sticks at the bottom, but if the window will be resized in height, the footer won’t follow … unfortunately
greetz
ray
Likes: 1 ❤
Remember that the window will open at a certain size and the footer will stick.
It is not normal to resize the window once it is open but if you refresh it will stick again.
So the script will work for devices of any size - try it on iPad/iPhone etc
Meanwhile I am looking into the CSS only version and implementing it on your page.
Likes: 1 ❤
purity
(purity)
March 29, 2016, 6:46pm
16
Yes, you’re right. I’ll also take a look at iPad and Phone. Thank you for the help!
A CSS version would be fine too – if you’ve one by the hand
As everytime best support on this forum!
greets and a nice evening
ray
Likes: 1 ❤
purity
(purity)
March 29, 2016, 6:53pm
17
one short question: the element’s extended value “footer” isn’t needed for your script, is it?
Likes: 1 ❤
Here is another version that will rerun the script on browser resize - may be performance issues on resize.
<script>
$(document).ready(function () {
updateFooter();
$(window).resize(function() {
updateFooter();
function updateFooter() {
if (height > 0) {
footer.css({
</script>
No - because this script uses the footer’s ID of footer and not the class.
purity
(purity)
March 29, 2016, 8:14pm
19
Hi Dave,
awesome, it works on desktop and with iPhone (Paddy get tested tomorrow). Great stuff! What difference would be between this and the CSS solution?
Thank you so much!
Greetz
Ray
Likes: 1 ❤
Have a look - there are some issues (with the CSS version) and the AutoClearfix (FW7) action so I have disabled it.
Likes: 1 ❤
