Everything I see on this subject seems out-dated or incomplete. I copied the widget from Twitter, put it as page>HTMLmarkup, and it shows up top left - pushing the website out of the way - tried putting before and after - indifferent places. I tried putting it as an insert>markup item, but it doesn’t show up. Added twitter follow and share buttons.
The feed on the link example is scroll down right - not a freeway site - but this is what I want.
Can someone kindly provide me with or direct me to some step-by-step instructions? I have looked all over the place.
Instead use Insert>Markup Item, paste your code into the dialogue box. OK it and then position the resulting markup item on your FW page, resizing as necessary.
Can you post a link to your page online where inserting a Markup Item is not working for you. There may be something else at fault.
