Adding a file input to a Freeway-generated form is easy. Insert a normal Text input where you want the file input to appear, then while that text input is selected, use Item / Extended to add a new attribute to the field:
But that alone will not solve the entire problem. Next, you have to alter your form so it can enclose file inputs. In the File Setup dialog, click on Extended, and add the following attribute:
- Name: enctype
- Value: multipart/form-data
But wait, you’re still not done! Now your form handler needs to know what to do with the uploaded file data. If you are using PHP Feedback Form to handle your form input, it does not include that feature – by design. File uploads are an easy target for hackers, so you have to know how to sanitize and quarantine those uploaded files, and Tim quite sanely does not want to get in the middle of that mess.
Forms To Go will generate a file-handling form processing script, and you can follow their directions (and pay for the application) to get this to work. But I still don’t recommend this for a newcomer to scripting or programming. It’s just too easy to bore a hole through all of the security on your server, and either facilitate taking down your server or another site on the same physical box.
On Jul 9, 2012, at 8:51 AM, Russ wrote:
Hi ,
Is here an easy way when creating a form/extending a form so that the user can add an attachment, in the kind of way you would attach a CV or covering letter?
I have the form working well, would just like to add this extra bit of functionality.
Any help greatly appreciated.
Russ
