[Pro] Adding Live Tweets to site
Hi All
Just working up a site for a client who would like his tweets and the tweets of the Racing Post to be live on his site.
I need advise on the best way to do this please.
Regards
Mike
Hi Mike,
These should do what you’re after:
https://dev.twitter.com/docs/embedded-tweets
https://dev.twitter.com/docs/embedded-timelines
Note that you’ll probably have to upload to see them working.
On 23 May 2013, at 10:14, Mike Thornley email@hidden wrote:
Hi All
Regards
Mike
What about the Freeway Chirp and Twitter follow actions?
Do these work in the same way.
Chirp will probably no longer work, since it doesn’t use the new Twitter API. Twitter changed the terms of their usage agreement, and the sorts of things you could do with Chirp are explicitly made illegal. The reason for this is that Twitter wants to force everyone to use their JavaScript client, since that one is designed to snoop on everyone who visits your page, whether they click on anything Twitter-related or not.
This is what I usually use : http://theodin.co.uk/blog/jquery/tweetable-1-6-launched.html
Github : GitHub - philipbeel/Tweetable: Tweetable - A jQuery plugin for displaying twitter feeds
