Hi, Gang –
At the top of this web page: http://www.businessesgrow.com/
…there’s a small video file. Any thoughts on how that was done? Is it a QuickTime file?
It seems to load very quickly, which is a key consideration of mine. Is it possible to do something like that with Freeway Pro?
Thanks!
Look at JW Player.
You will have to purchase the player if you want it free from ads. Load time and quality will depend on the compression.
Script is required. They are pretty helpful.
Thanks, Sampolfonz. I’ll check them out.
I also came across this information about ScriptyLightbox2 on the Freeway Talk Forum: http://actionsforge.com/actions/view/215-scriptylightbox2
Thanks!
– Jamie
Look at JW Player.
Also look at Walter’s Sublime Player action http://actionsforge.com/actions/view/248-sublimeplayer
Is it just a player you want or a lightbox effect too?
