[Pro] Advert won't display
I’ve imported html for an advert box from here < http://www.kiva.org/app.php?page=businesses&action=about&id=100142&utm_source=viralbanner&utm_medium=viral&utm_content=tower160x380&utm_campaign=banner > (scroll to bottom of page) that I want to show on my page. I have made a box the size of the advert, imported the given html and all that shows in both safari and firefox in the code displayed. What do I need to do to get the advert displayed?
Jan
FWPro 4.4.2 OSX 10.5.5
Freeway has a couple of containers for HTML code, although I can’t
tell you how to use them as I’ve never done it. Look in the manual,
and search on this forum, for ‘HTML item’ and ‘Markup item’.
best wishes,
Paul Bradforth
http://www.paulbradforth.com
Insert>Markup Item
This will open a dialogue box into which you paste your HTML code.
Click OK and it will place a 100px x 100px box somewhere on your page.
Resize to suit your ad - you may need to preview it to get it right - and position it on your page.
Remember you may or may not need to make it a layer depending on your page layout. It can also be copied and pasted into another html box or table.
David,
That worked a treat.
Jan
