Okay, this is a little silly, but it’s really starting to annoy me so I’ll just throw it out there.
As you know, there are at least three different ways to access installed actions in Freeway Pro.
Item > Actions
Page > Actions
Action icon in toolbar
I suppose I can understand the reason for all of these, since some are only applicable to certain things, but what I don’t understand is why the pull down menu that pops up is not alphabetized. I’ve wasted tons of time just trying to find an action I need.
They are alphabetical, unfortunately it’s alphabetical by filename. If this really bugs you, you could open up your ~/Library/Application Support/Freeway 5/Actions/General folder and rename the files you find there. Note that some Actions will not get a better sort this way, because a single file may contain a number of different Actions, and once you have gotten past the initial sort by filename of the Action file itself, the source order within the Action itself is your only sort mechanism.
You might want to post a feature request at Softpress support, though, it’s a good idea.
Item > Actions
Page > Actions
