[Pro] Alt text
Hi all,
I’m changing a website I’ve made a year ago in Freeway Pro 5.4.1 and when after I’ve uploaded the website there is an alt text desapearing in the browser (Safari, IE, Firefox), when the mouse goes over a submenu in the CMS menu, who isn’t correct. I don’t get it. The CSS menu is made in a master page en the submenu is linking to a page what is renamed in the inspector menu. Even after several refreches I still get the old page name as alt text
Any ideas?
I’m using Freeway Pro 5.4.2
Best regards,
Bart
Remember that not only do Browsers have cache files but Servers do too.
It may be that your server is showing cached files and it is only time that will change that.
If you post a link to affected page(s) with what we should expect to see then others can check for you to see if it is a cacheing issue or not.
Try this, Bart:
  1. Select any items you have changed that have the wrong alt text.
  2. Go to the Inspector and click on the third tab from the left (looks
    like a mini web page)
  3. At the bottom, under Alt Text, type in the correct words.
Upload and refresh the page in your browser and see if that corrects
the problem.
HTH Colin
Hi David and Colin,
Thank you for the answers.
The CSS-menu is in html, so I don’t can add Alt Text if i’m correct.
The wesite can be viewed on labadoux.be In the menu you see ‘festival’ and in this submenu you have ‘programma’ > ‘algemeen’. When the mouse goes over ‘algemeen’ you see 1-2-3 mei 2009. The title of the page this year is ‘Programma Labadoux 4-8-9 mei 2010’.
When you Create/Edit a Hyperlink in FW a dialogue box opens.
If you select a page from internal/external there is a section below where you can add a Title. It is this Title that is used as your Alt text. Change/add it here (but on your Master) for a site wide alteration.
Hi David,
I never clicked on this little buttom before as far as I can remember, I always used the one on the right of it, to make a link. It’ all so easy when you know it. I don’t think I should have find it without your help!
Thank you very mutch David and Colin,
Best regards,
Bart
