Hi,
I’ve added some text product links on my website using Amazon’s product previews script.
The effect is just as it should be on Firefox (both Mac and PC): scroll over the highlighted words and a pop-up box appears with details of how to buy the product from Amazon.
Using Opera on the Mac, no pop-up appears but you can click normally on the link, so I can live with that.
Using the lovely Internet Explorer 7 on a PC, however, it’s as if the pop-up boxes are appearing behind the page (you can sometimes see the edge of one, peeping out to the left of the body text). Not only that, but when you scroll over the highlighted text, it propels the page upwards. To add insult to injury, it’s not displaying the underline that should be there.
Any clues about fixing it?
I’ve been trying it on this page:
http://www.theatreSCOTLAND.com
Look for the phrase X-Men in the second paragraph and other phrases in green text further down the page.
I’m using Freeway 5 Pro with compatibility set to IE6/IE7. I added the links using Insert>Markup Item…
Thanks for your time,
Mark
