Does anyone know how to do this in Freeway? There are conventional hand coding ways to do this, and although it is quite easy to include these within a Freeway-built site, the method I’m using fails because of the automatic inclusion of the PageDiv.
Ideally I need to be able to remove this - a plug in would be great, but at the moment the only way seems to be manually using Source Code Snooper. Not ideal.
I made this holding page by this method:
http://docmailpayslip.com/
A larger site would be a real pain to have to go into the code for every client update.
Does anyone know a way of achieving this without having to remove the PageDiv in code?
MAtt ![]()
