Hi all, having a small problem with Anchors. I have a few set up that scroll to different parts of a page which work fine when they need to scroll down the page but if the page needs to scroll up to get to an anchor the page scrolls all the way to the top. Has anybody had this problem and if so is there a way to solve it?
Many thanks,
Spike
Here’s a link to the page I’m having the anchor problems on http://spyk.co.uk/sticker
So far I’ve only activated the links for Alaska, Colombia and Fernie.
Spike
Works fine here in Safari 5.1.8
I will try other browsers later
Thanks Dave,
I carried on playing with it and used empty graphic elements instead of the large images which seemed to fix it.
Spike
