[Pro] Another Scripty Accordian question
Hi,
I downloaded Scripty Accordian for FW Pro. I installed it as directed, but it does not show up under the Page | Page Actions menu. It does show up under Insert | Action Item. Is this where it’s supposed to be as whenever I try to apply it to my html section it simply inserts a Scripty Accordian box. I can’t apply it via the Page Actions menu. I’m probably doing something wrong here, so if you could point me in the right direction I would be very appreciative.
Thanks very much!
Mike Frederick
Probably not much help…
For this to work, you need to make all of your accordion content within a single HTML box. You may use any combination of elements you like, as long as the headers and the hidden elements use different container types…
So once you make the HTML box it should show in actions item – yep, just check and there it is.
The rest of the first paragraph is located here:
http://www.actionsforge.com/actions/view/110-scriptyaccordion
Good luck!
Frank H.
On Jul 17, 2011, at 7:11 PM, Michael Frederick wrote:
Hi,
Thanks very much!
Mike Frederick
Just to clarify. ScriptyAccordion is applied through the Item>Actions menu
So select your HTML box that will be the ‘container’ for your accordion effect Item>Actions>ScriptyAccordion (near the bottom of the list)
