I’ve added an .swf audio player as an html item, under the banner and added some markup code as per the installation instructions, which has resulted in a player that sees the .xml playlist but appears outside the site in the top left corner, ideally I want one player that sees the playlist in the position under the banner to the right, any suggestions gratefully received.
It also appears that the paths to your mp3 files in the playlist are incorrect. Did you manually upload these yourself? The XML file is looking for them inside the test2 folder.
Both work for me but how big are your mp3 file sizes?
The other thing I would be careful of is your file names - I would stick to all lowercase file names and make sure there are only alphanumeric characters and no spaces or other odd characters etc. in them.
Sadly it’s not working at all today on my machine and I’ve reset safari and cleared the cache etc, I was told it was working else where however. It’s too inconsistent to trust so I’m beginning think about dumping it altogether, it seems lots of other folk have had similar problems with this player if you see their forums and don’t get much response from the company.
It’s a shame as it looks right for this site but I’m wasting so much time now and need to get the job done, if any body can recommend a player that might be less trouble, please do, thanks for your help
not sure if what the problem is, the premiumbeat player was pulled from their site as of today, I guess they decided it was more trouble than it was worth to them.
