If you don’t mind a user interface only a nerd could love, there’s this little Ruby script I wrote a year or more ago:
http://scripty.walterdavisstudio.com/get_versions.zip
To use, decompress the zip file, and open up the Terminal application (Applications/Utilities/Terminal) on your Mac. In Terminal, type the letters cd (followed by a space) then drag the Finder icon of the decompressed get_versions folder into the Terminal window. The command line will expand to look something like this:
yourname$ cd /Users/yourname/Downloads/get_versions
Press return, and your terminal will be “in” that folder. Type the following command to install the Nokogiri XML parser:
gem install nokogiri
If you immediately get an error saying that you don’t have the “gem” command, then skip to the PS at the bottom where you will get the one-line fix for all that ails your Ruby environment. If not, you should see exactly nothing for a couple of minutes while Nokogiri installs, followed by some lines of explanation of what was installed (and, usually, some Unicode errors from the documentation installer).
Once all that is done, you can use this tool. If you are still using Freeway 5.5 or later, then issue this command:
ruby ./get_versions.rb
If you are using Freeway 6 or later, then the command you will use is:
ruby ./get_versions_6.rb
You will see a list of all the Actions that the script was able to read, and their version number. Note that encoded Actions are not readable by the script, so they get skipped. These may include Actions you paid for, or Actions that were encoded to make them usable on Express.
Hope this helps,
PS: To fix your Ruby environment, type the following (exactly!) in Terminal:
\curl -L https://get.rvm.io | bash -s stable --ruby=1.9.3
You will see a bunch of explanation and colorful text, and then you will magically have a working Ruby environment. You may be prompted to install the GCC interpreter, but the error message is very simple and if you copy-and-paste what it tells you to do into your terminal, you will get everything ready to go.
On Nov 7, 2013, at 2:42 PM, RavenManiac wrote:
I didn’t realize that. Thanks Dave. It would still be helpful to have them all in one place though.
