Question… I’m stuck here and need a hand. I am re-designing my site for mobile use. I have re-created my home page in a mobile format, and when I did, I was able to resize my Exhibeo import to fit the new window size (iPhone for example), landscape, etc, and each time I made the Exhibeo import window whatever size, the slideshow within would resize.
Now onto the next page, I copy/pasted the same box onto another page formatted the same and the Exhibeo import slideshow isn’t resizing so it isn’t fitting within the window. I have gone back and forth between the two pages to see if any differences but I cannot locate any. Am I overlooking something simple here?
Oh and to add, if within the action pane I select the “home page” slideshow, rather than the one I’m trying to use, it fits in the box perfectly as I would like the others! I don’t know why that’s the case because I didn’t do any resizing of the home page slideshow in Exhibeo.
Did you ever get to the bottom of your problem? If not, send your files to support(a)softpress.com and the Support guys will be happy to have a look.
Cheers,
