[Pro] Backdraft moving/sizing a module height
Hi
Hopefully a very simple question…
I am toying with Backdraft and have been looking at the Backdraft Docs - I get the main principal but struggling how to do the following…
I want to move modules up/down (or resize) so the gap between the Header and the ‘One Image module’ is not so large ?
I know how to change the page colour to get rid of the grey - but the gap between the header and the main image is to big.!
here’s what i mean http://jd-interiordesign.co.uk/responsive/
thanks
Steve
Reduce the Margin top and bottom of the backdraft wrapper.
Noel is dead-on about reducing the top margin. Almost every module in Backdraft has a 20px top margin as a “sensible default”. You can this this like so:
  1. Using Freeway’s sidebar, select the module’s wrapper element (e.g. twoWrapper).
  2. In the Dimensions section of the first pane of the inspector, click on the Margin dropdown.
  3. Select Custom.... This will open a dialog which will allow you to adjust the top margin.
Thanks guys… I did actually adjust margins but did not delve into ‘custom’ cheers
