Also with Caleb’s great BACKDRAFT template:
Thx for your help Caleb and Justin!
Feedback is welcome
Erik
Feedback is welcome
Erik
Looks good Erik, but you may want to fix your H1 font leading so when you reduce the page width and the heading goes to two lines there’s more vertical space between your headings.
This was occurring on a desktop with reduced window width. Not sure what it looks like on an IOS device.
This can happen if you set a base line-height in the body tag (or another ancestor to the header) in a fixed unit. Say you set body to 14px/19px – that looks fine in the P tag and the LI tag, but just about nowhere else. If you set the body font to 14px/1.36, then you get a nice scaled line-height no matter where you go.
Walter, is the latter number of 14/1.36 a percentage?
It’s a ratio, not a percentage. But that works out to look nearly identical to 19px leading. (If you really want to be pedantic, it’s about 8 decimal places longer.)
Erik,
It looks nice!
However, it appears that you forgot to upload the engine1 folder from WOWslider to your server: http://cl.ly/Ppcr.
In the mobile drop-down menu, it seems that “Webdesign” is not linked to any page, and you need to set the default option to the # that the current page is.
Otherwise, you did an excellent job. The website is beautiful, and responsive to boot!
Looks lovely, A few things I’m sure you have covered…
Some of pages scroll left/right
navigation being left aligned leaves an odd gap between CMS and Portfolio.
Can the webyep ‘padlock’ graphic be changed to something more contemporary or hidden.
Some of the pale blue headings are a different point size on the ‘responsive’ page.
Just nit picking - its gorgeous.
s
Thank you all for your feedback,
I fixed the header thing and vertical alignment is better, thx RavenManiac.
Caleb, I think you have the refresh your browser because I removed the wow slider a while ago?
I cleared my cache, and it’s still referencing the files. I think that you just forgot to remove the references to the CSS and javascript from right after the page , per this: http://cl.ly/PrHB
And now? I think I removed it!
All fixed now!
Thank you for checking Caleb!
