Hi everyone,
I’m having a bit of a problem trying to set the background colour of my site.
Essentially what I’d like to achieve is a white ‘internal frame site’ colour and a grey ‘background’ around it.
I created a HTML box on the master page and made it white. Then sent it to the back. Then I changed the background colour of the site to grey. So all good there.
Once I publish the site though many elements on the page are now white. Even if I go to the page they’re on and bring them to the front they still remain hidden.
Any thoughts?
Yours gratefully,
Mark
Can we see it?
Hi Dave,
Thank you for your prompt response.
Thankfully though, after a great deal of playing about, I managed to work it out.
Thanks again.
Mark
Share your solution for others that might have a similar issue.
Hi D,
Good point.
I realised that the objects that were being hidden hadn’t been checked as layered items.
As soon as I’d checked that box, then sent them to the front, it worked perfectly.
M
