Does anybody know why when using the ‘Background Supersizer [0.3.2]’ with other actions on a page causes them to not to work properly?
I have tried using Transition FX and Target hide/show layer with the Background Supersizer but can’t get them work together… when removing the Background Supersizer the other actions work fine.
I updated Background Supersizer for Softpress and sent it to them for vetting and posting to the Forge. As soon as they do that, and you update your copy of the Action, you should be able to use it with Prototype-based Actions in the same page.
On Oct 15, 2013, at 3:50 PM, Jef wrote:
Hi, this worked for me:
go to: Page - HTML markup - Before Head (second one):
Walter, does the Background Supersizer action work with responsive websites?
I’m not sure. All I can say is give it a try. I’m pretty sure it recalculates its big image when the window is resized. Note that it won’t do anything besides try to cover the entire screen, regardless of the aspect ratio. It won’t resize the image differently at different screen sizes/orientations.
