[Pro] Base Scale Responsive Template
In my downloads folder there’s this ‘Base-Scale-Responsive-Template’ I obviously downloaded a couple of months ago. I absolutely don’t recall the event, neither do I ave any clue how I came about this template in the first place …
It. Is. A. Freaking. Awesome. Template.
But to return to the reason of this post, where does this template come from (again), who’s build this?
– Tnx, Richard
Its a Max thing :slight_smile:
Ahhh, right. Most action used were Max’s … I should have known.
Hi Richard that template originally started off as a way of getting some sort of structure to the style sheet e.g. ordering and from that initial version lots of other things grew so in the end I ended up with a typographical style sheet which contained a starting off point for forms tables etc. In my version of Freeway I also have pantone swatches installed for colours and access to a css and html cheatsheet from within the application. I never got a chance to explain my thoughts (unfortunately I have too much work!!!) so it may have been a little daunting for people to undesrtand but if you found it useful then thats great.
Oddly enough I went bit further with it recently where by I introduced Codekit into the work flow and that was purely so that I could have a css checker for all the hand written css within the template and because i wanted to use PostCSS / Rucksack for real responsive typography http://simplaio.github.io/rucksack/docs/
if anyone had had any thoughts about the approach or feed back then it would be good to know
All the best Max
Forgot to say and I am assunimg you have probably already worked out that a lot of the css is only really visible within a proper browser for example how hyphanantion and the orphan control works, although things like tables, forms and the maintenance pages are visible correctly within the freeway preview.
If I get a chance tonight, I will post an updated version of the template if anyone wants to have a look at it
all the best Max
Thank you for sharing this in the first place, Max.
I just found the thread where you posted it for ‘us’ to download. As I understand you’re pretty occupied at the moment, but if (and only if) you do find the time … your offer to record a screencast and explain the purpose of it (and the actions) would be mostly appreciated.
– Richard
Oh, goodie!
Latest version of the base scale template with a few adjustments
This version now has an extra Typographical page and associated css style sheet for that page which allows me to use rucksack (http://simplaio.github.io/rucksack/docs/) which allows an easily conversion for the styles required to make real scaleable responsive text (http://simplaio.github.io/rucksack/docs/#responsive-type)
I use Codekit (https://codekitapp.com) to compile the Freeway site folder and then use a hook within Codekit (CodeKit - Hooks) to run Rucksack css conversion into real css
Link to template:
I have included a commented instructions on what needs to be written within Codekits hook panel so it can use rucksack and thats within the rucksack.css sheet
I know this sounds quite complicated but in reality this isn’t needed if you are not interested in what Codekit or Rucksack can do
speak soon max
Wow, thank you for your generosity and sharing your work. I’ve downloaded and installed it … let’s see how far I can get own my own without any further information; the actions used for instance are complete new for me, so is the set-up. But even though my ‘professional’ focus has shifted towards Coffeecup, this seems time well spent to me. Let’s give it a go :slight_smile:
– Richard
