[Pro] best photo format to use
I am doing a fairly basic website and was wondering what is the best format to use for photos jpg, tif png etc. I’d like my images to be as sharp as possible.
jpg/jpeg
Quality will depend on the sharpness applied in whatever program you are using; photoshop, etc… , quality setting when exporting out, file size. I would also suggest (depending on your subject matter) add a little boost to your contrast.
jpg’s can be run through JPEGmini lite to reduce file size a bit.
Though Freeway can import images it is best if you can, perhaps at last stage import images at the required size as pass through.
s
If you are looking for best quality images.
But if you are building a standard site then FW’s image handling is perfectly good.
Out of pure coincidance I’ve just read this: http://fstoppers.com/the-secret-to-crafting-stunningly-sharp-images-and-preserving-it-across-medias
s
