Can you please suggest the best way to make a fading slideshow where I am NOT using pictures (like most slideshows) but rather text (like quotes from prior users) that I would like to easily change if needed.
Most things like WOW, Exhibio, Hype etc seem much more involved.
Is there a FW action for this?
Does anyone have an example I can see?
Barry
Thanks Richard. Just found it and it is exactly what I needed. While not the most innovative- I can slide html text boxes (which I used table cells) and change background, center vertically, etc)
good for my need
Thanks!!
Barry
I just happen to run into this action last week, it was mentioned in some thread here β¦ Iβve never used it myself though, but thatβs how I remembered it
Good luck!
Richard
