need some help with the blog page I’ve set up on the above site.
The content should be white text, which it is on the blog, but if you post a comment below the name and content are coming up as the default colours (blue & black) even though I have set them to purple & white in Freeway. I have re-uploaded the site and re-pasted the code into e-blogger but still not working.
Any ideas of why this won’t work, and how I can resolve it?
I don’t really want to change the page background to white as the whole site is black, it will look odd.
It looks like a couple of things have changed in the Blogger code. I’ll get them logged and we’ll hopefully have a fix soon. In the meantime, you could try adding the text color and font family to the p style (or a new body tag style) in Freeway. That should at least mean that all your text can be seen for now.
To add a new body tag style, go to Edit>Styles… and click the + icon to add a new style. In the Tag field type body and delete the text from the name field. You can then add the properties you want the text in your site/page to use by default. You don’t need to apply this style to anything, it will automatically be picked up by the body tag and applied to all text that hasn’t got an overriding style applied.
Hope this helps,
On 7 Sep 2013, at 14:23, NeilMM email@hidden wrote:
Hello all,
