Lena
(Lena)
May 1, 2011, 3:40am
#1
Hi!
I have followed all the steps shown in the tutorial for creating blogger templates and still no pictures (background etc).
When i have a look at the code it sais XHTML Transitional…the tutorial sais Strict.
I have tried to change that, i have even started a brand new template and made sure it was Strict from the beginning.
Please help…i really really need to make this work.
Kind regards Lena
A link to your page would help.
Lena
(Lena)
May 1, 2011, 12:02pm
#3
Hi David!
http://kryte-lissage.blogspot.com/
I have used a Freeway Blogger template for this and just uploaded it…
L
Dan_J1
(Dan J)
May 1, 2011, 1:03pm
#4
Try adjusting your “Web Address” to include a “http://” instead of just the straight “www.”
Lena
(Lena)
May 1, 2011, 1:33pm
#5
Dan…i think im slightly in love with you!
U just made my year.
TONS of love from Gotland, Sweden!
Lena
Dan_J1
(Dan J)
May 1, 2011, 5:59pm
#6
Glad to help out. Take care.
Lena
(Lena)
May 2, 2011, 2:45pm
#7
Hi David!
Its me again
Have a look at: http://kryte-lissage.blogspot.com/
Do u have any idea why i get transparante fields when i insert a blogger action onto background field and white graphics field?
L
I have looked at this and what I see is gaps opening up when I increase the text size.
In Safari try selecting Zoom Text Only under the View menu and then use Apple+ and Apple- to increase and decrease the text size.
The gaps are caused by your layout breaking apart - to avoid this you should try using an inline (Box Model) layout.
You may be able to use the RPL action but I am not sure if it will work on a blogger template.
