[Pro] Blogs and webyep
Is it possible to create a blog in freeway pro that the client can access via webyeb?
Sure. If you also add the Disqus service to it, you can have comments, too. There’s instructions here: http://www.softpress.com/kb/questions/36/Blogs+in+Freeway
Adding WebYep to this would be a great way to make it remote-updateable. You might also want to look at Perch or Pulse, two simple CMSs that both include blog features.
Hi Bob
actually if your blogging needs aren’t to massive then it can be done in webyep
here is an example where by the client can add a blog post
http://www.sophieyershonphotography.co.uk/blog.php?DOC_INST=19
she has only added two posts for the moment and I do need to move the comments so they are with the individual blog post but it is quite achievable. As long as it’s a small amount e.g. once or twice a month and not 365 posts a year then yes webyep can be made to to work like a blog
Thanks all. The site is up and uses web yep. If i add the blog in Pulse Pro will that cause a conflict with web yep or am I best just to stick with web yep?
Hi Bob pulse pro is an alternative cms system and I have no idea if the two can live together if anyone has tried it then it would be interesting to know
max
