On Feb 15, 2015, at 12:12 PM, Jessica email@hidden wrote:
The Title tag is one of the richest elements with respect to search engine optimization. The Title and the first H1 on the page should be related or very similar to one another, and if you go the extra mile when linking to your page, the Title attribute of the link to the page should be exactly the same as the Title tag of the page you are linking to:
my-excellent-page.html
My Excellent Page | My Fabulous Site
My Excellent Page
some-other-page.html
My Excellent Page
That’s a very strong link, because the title tag matches from the anchor (a tag) to the page it links to, and the link text (contents of the a tag) is exactly the same as the H1. There is no confusion on the part of a human or a robot that these pages are related directly.
Thanks for your input, however I am not sure if I completely understand. I am new to this. I am an artist and built a site for viewing my work. Most of my hyperlinks are internal and connect to each other to see a body of work. None of my pages are long so why would I need an anchor?
Anchor is the proper name of the <a href="something">Something</a>
tag. When you link to a part of the page using its ID, and the URL contains only the ID of that element, you may hear that referred to as an “anchor”. But really, the a in a link comes from the fact that the tag itself is named anchor, and whether the URL within its href attribute contains a #some_id segment or not, it’s still an anchor tag.
What is H1?
There are 6 different header tags, with the code being <h1>Text</h1>
through <h6>Text</h6>
. You can create these using the Styles palette in Freeway. There are (by default) tags defined for h1, h2, and h3, but you can create the other three as well. Headers are used to identify content areas within the page, and to give them a hierarchy. Think of them as the outline of your text content.
How do you alter internal hyperlinks? In the “Edit Hyperlink” Box and then click on “extended”?
If you highlight the text and press Apple-K to open the Edit hyperlink dialog, you can use the interface to add a title to your link. You don’t need Extended for this.
- Is it ok to use special characters (dividers) in the title box
“Jessica Liggero⎜Boobs, Balls & Boxing”
Sure. This is common. Just make sure your page is set to publish as UTF-8 (Unicode) rather than any other character set.
Where can I change that setting? I went to “Document Set-up” and could not find anything about UTF-8 (Unicode)?
Each page has its own output tab in the Page Inspector, and you set this property there. By default, Freeway will be set to Automatic, which usually means Unicode, but it is also possible for a page to be set to a different output mode.
Jessica
