I’m having a situation where there are sort of “blurry boxes” around my text on a page. the boxes appear to be somewhat (but not totally) behind the text and going out to the edges of the Graphic Items that contain the text. it creates an almost “halo” effect around the words that I really don’t want. Any way to fix this?
This is probably an anti-alias problem. Are these text boxes on top of coloured layers or picture backgrounds.
If so you may have to adjust your AA settings. First check if AA is on. (In the Inspector palette) If on and set to auto you may have to choose an AA colour to suit the background better.
But as Marcel says a link would help diagnosis
When posting a link use the full web address including the http:// and then it will be a clickable link for us.
Hi, sorry it took me a little while to respond.
I had to upload the new site so it could be viewed. You can take a look here: http://www.mark-williams.com
the problem i’m referring to is around the little words on the navigation bar.
As I said - check your anti-alias settings. Because this text is against a transparent background you may have to manually tweak them. Also is the text set to output as gif or png, might be worth toggling between the 2
